Brief Description: Fit and updrill right forward brackets
Fitted the right forward corner brackets. Found it faster to start with agressive grinding for a rough fit on the radii inteference areas, then smooth on the belt sander, then smooth with the ScotchBrite wheel.
Updrilled the forward right corner brackets on the side and top for rivets and AN3 screws. I will enlarge the forward holes on the glare shield to clear the top AN525-10R12 bolt heads. This will allow easy removal of the glare shield if needed.
